Asymptotic Expansion of Steady-State Potential in a High Contrast Medium with a Thin Resistive Layer - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2010
Ronan Perrussel
We study the steady-state potential in a high contrast medium with a resistive thin layer. We provide asymptotic expansion of the potential at any order. Transmission conditions at any order and the corresponding variational formulation are given. We prove uniform estimates with respect to the thickness of the layer and with respect to its resistivity. The main insight consists in the uniform variational formulation whatever small the layer conductivity is. Numerical simulations illustrate the theoretical results.
RR-7163.pdf (402.88 Ko) Télécharger le fichier
inria-00442659 , version 1 (06-01-2010)
inria-00442659 , version 2 (07-06-2011)
  • HAL Id : inria-00442659 , version 1
Ronan Perrussel, Clair Poignard. Asymptotic Expansion of Steady-State Potential in a High Contrast Medium with a Thin Resistive Layer. [Research Report] RR-7163, 2010, pp.22. ⟨inria-00442659v1⟩
Collections
INRIA-RRRT AMPERE
632 Consultations
431 Téléchargements
