Asymptotic Expansion of Steady-State Potential in a High Contrast Medium with a Thin Resistive Layer - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Applied Mathematics and Computation Année : 2013
We study the steady-state potential in a high contrast medium with a resistive thin layer. We provide asymptotic expansion of the potential at any order. Transmission conditions at any order and the corresponding variational formulation are given. We prove uniform estimates with respect to the thickness of the layer and with respect to its resistivity. The main insight consists in the uniform variational formulation whatever small the layer conductivity is. Numerical simulations illustrate the theoretical results.
RR-7163.pdf (2.79 Mo) Télécharger le fichier
inria-00442659 , version 1 (06-01-2010)
inria-00442659 , version 2 (07-06-2011)
Ronan Perrussel, Clair Poignard. Asymptotic Expansion of Steady-State Potential in a High Contrast Medium with a Thin Resistive Layer. Applied Mathematics and Computation, 2013, 221, pp.48-65. ⟨10.1016/j.amc.2013.06.047⟩. ⟨inria-00442659v2⟩
632 Consultations
431 Téléchargements
