Conference papers
3D Geometric and Haptic Modeling of Hand-Woven Textile Artifacts
Abstract : Haptic Modeling of textile has attracted significant interest over the last decade. In spite of extensive research, no generic system has been proposed. The previous work mainly assumes that textile has a 2D planar structure. They also require time-consuming objective measurement of textile properties in mechanical/physical model construction. A novel approach for haptic modeling of textile is proposed to overcome the existing shortcomings. The method is generic, assumes a 3D structure textile artifact, and deploys computational intelligence to estimate textile mechanical and physical properties. The approach is designed primarily for display of textile artifacts in museums. The haptic model is constructed by superimposing the mechanical model of textile over its 3D geometrical model. Digital image processing is applied to the still image of textile to identify its pattern and structure. In order to deal with the non-linearities associated with the textile, a fuzzy rule-based expert system is deployed. This information is then used to generate a 3D geometric model of the artifact in VRML. Selected mechanical and physical properties of the textile are estimated by an artificial neural network with the textile geometric characteristics and yarn properties as inputs. The neural network learning and verification and validation processes are carried out by a sample data set. The mechanical properties are used in the construction of the textile mechanical model. The haptic rendered model is generated by superimposing the physical/mechanical model over the 3D geometric model. This model has been implemented and rendered in Reachin environment, provided an interactive Virtual Reality environment where the user can navigate the graphic 3D presentation of the textile and touch it by a haptic device. Different samples have been modeled and the whole approach has been validated. The interface can be provided in both in the physical environment and through the cyberspace. The validation of method indicates the feasibility of the approach and its superiority to other haptic modeling algorithms.
Document type :
Conference papers
Complete list of metadatas
https://hal.inria.fr/hal-01056329
Contributor : Hal Ifip <>
Submitted on : Monday, August 18, 2014 - 5:12:41 PM
Last modification on : Friday, August 11, 2017 - 11:26:31 AM
Document(s) archivé(s) le : Tuesday, April 11, 2017 - 7:56:16 PM
File
9-paper_28Shidanshidi_29-A.pdf
Identifiers
Citation
Hooman Shidanshidi, Fazel Naghdy, Golshah Naghdy, Diana Wood Conroy. 3D Geometric and Haptic Modeling of Hand-Woven Textile Artifacts. Second IFIP TC 14 Entertainment Computing Symposium (ECS) / Held as Part of World Computer Congress (WCC), Sep 2010, Brisbane, Australia. pp.87-100, ⟨10.1007/978-3-642-15214-6_9⟩. ⟨hal-01056329⟩
Share
Metrics
Record views
544
Files downloads
323
