Conference papers
Determination of Thermal Conductivity of Aloe in the Cooling and Thawing Process
Abstract : In this study, thermal conductivity of aloe was determined in the cooling process from 20°C to -11°C, and in the thawing process from -11°C to 20°C using the tiny thermal probe method. The tiny thermal probe measurement system had the advantages of high accuracy, short test time, low temperature rise and little water removal and was found to give accurate and consistent experimental results. The results showed that the thermal conductivities increased with temperature over the freezing point. The thermal conductivities rapidly increased below the freezing point and it increased with the temperature decreasing. The thermal conductivities decreased with temperature below the thaw point. The thermal conductivities rapidly decreased over the thaw point and it decreased with temperature. The thermal conductivity of aloe in the cooling process was greater than that in the thawing process at the same temperature.
Document type :
Conference papers
Complete list of metadatas
Cited literature [12 references]  Display  Hide  Download
https://hal.inria.fr/hal-01559562
Contributor : Hal Ifip <>
Submitted on : Monday, July 10, 2017 - 5:27:55 PM
Last modification on : Thursday, March 5, 2020 - 5:42:04 PM
Document(s) archivé(s) le : Wednesday, January 24, 2018 - 4:43:20 PM
File
978-3-642-18333-1_68_Chapter.p...
Identifiers
Citation
Min Zhang, Huizhong Zhao, Zhiyou Zhong, Jianhua Chen, Zhenhua Che, et al.. Determination of Thermal Conductivity of Aloe in the Cooling and Thawing Process. 4th Conference on Computer and Computing Technologies in Agriculture (CCTA), Oct 2010, Nanchang, China. pp.569-575, ⟨10.1007/978-3-642-18333-1_68⟩. ⟨hal-01559562⟩
Share
Metrics
Record views
89
Files downloads
153
