Artificial Intelligence Applications and Innovations 12th INNS EANN-SIG International Conference,EANN2011 and 7th IFIP WG 12.5 International Conference, AIAI 2011 Corfu, Greece, September 15-18, 2011, Part II
Abstract : In this paper a new criterion for clusters validation is proposed. This new cluster validation criterion is used to approximate the goodness of a cluster. The clusters which satisfy a threshold of this measure are selected to participate in clustering ensemble. For combining the chosen clusters, a co-association based consensus function is applied. Since the Evidence Accumulation Clustering method cannot derive the co-association matrix from a subset of clusters, a new EAC based method which is called Extended EAC, EEAC, is applied for constructing the co-association matrix from the subset of clusters. Employing this new cluster validation criterion, the obtained ensemble is evaluated on some well-known and standard data sets. The empirical studies show promising results for the ensemble obtained using the proposed criterion comparing with the ensemble obtained using the standard clusters validation criterion.
https://hal.inria.fr/hal-01571447
Contributor : Hal Ifip <>
Submitted on : Wednesday, August 2, 2017 - 4:21:57 PM Last modification on : Thursday, March 5, 2020 - 5:41:56 PM
