High Resolution Actuators for Severe Environments
Abstract : Stepping Piezo Actuators (SPA) are long stroke linear piezoelectric actuators able to perform long stroke (typ. >10mm) with an important resolution (typ. <1nm). Use of famous Amplified Piezo Actuator APA® gives the motor interesting characteristics, such as useful deformation mode and speed improvement, compared to standard inertial motors.The paper proposes experimental results obtained on various size of SPA. Speed aspects and max input current are considered as well as non-magnetic and thermal vacuum compatibilities.
Document type :
Conference papers
Liste complète des métadonnées
Cited literature [7 references]  Display  Hide  Download
https://hal.inria.fr/hal-01363887
Contributor : Hal Ifip <>
Submitted on : Monday, September 12, 2016 - 10:05:49 AM
Last modification on : Monday, September 12, 2016 - 2:22:51 PM
Document(s) archivé(s) le : Tuesday, December 13, 2016 - 12:58:43 PM
File
978-3-642-28163-1_12_Chapter.p...
Identifiers
Citation
Christian Belly, Mathieu Bagot, Frank Claeyssen. High Resolution Actuators for Severe Environments. 6th International Precision Assembly Seminar (IPAS), Feb 2012, Chamonix, France. pp.89-96, ⟨10.1007/978-3-642-28163-1_12⟩. ⟨hal-01363887⟩
Share
Metrics
Record views
35
Files downloads
58
