Characterisation of High Accuracy, Feedback Controlled, Adhesive Bonding
Abstract : Adhesive bonding for industrial purposes has, over the last years, become more important compared to conventional joining methods, due to application in miniaturized systems where other ways of joining are too bulky. These days’ industries have to deal with the challenge of applying adhesive bonds with small tolerances, while the geometrical dimensions of the applied adhesives change due to the curing process of the bond. This effect is called ‘adhesive shrinkage’. This paper explains the effects of adhesive shrinkage, during bonding processes, on internal bond stress and the influences on position accuracy of the adherent parts. Effect of parameters like curing time, gap size between components and adhesive volume are studied. This is done by use of a test setup containing a manipulator with force sensor to simulate an industrial setup for the application of similar adhesive bonds. Results show that the gap-size has influence on shrinkage behaviour, whereas the adhesive volume, which defines the cross section area of the bond, is less important. Results can be used to develop a bonding procedure, which leads to an optimal balance between position accuracy and bond stress, thus guaranteeing a reliable and accurate bond in industrial manufacturing environments.
Document type :
Conference papers
Svetan Ratchev. 6th International Precision Assembly Seminar (IPAS), Feb 2012, Chamonix, France. Springer, IFIP Advances in Information and Communication Technology, AICT-371, pp.144-153, 2012, Precision Assembly Technologies and Systems. 〈10.1007/978-3-642-28163-1_18〉
Liste complète des métadonnées
Cited literature [7 references]  Display  Hide  Download
https://hal.inria.fr/hal-01363895
Contributor : Hal Ifip <>
Submitted on : Monday, September 12, 2016 - 10:07:03 AM
Last modification on : Monday, September 12, 2016 - 2:22:50 PM
Document(s) archivé(s) le : Tuesday, December 13, 2016 - 12:58:28 PM
File
978-3-642-28163-1_18_Chapter.p...
Identifiers
Citation
Rik Lafeber, Gerrit Bosch, Max Murre, Jitze Bassa, Leo Moergestel, et al.. Characterisation of High Accuracy, Feedback Controlled, Adhesive Bonding. Svetan Ratchev. 6th International Precision Assembly Seminar (IPAS), Feb 2012, Chamonix, France. Springer, IFIP Advances in Information and Communication Technology, AICT-371, pp.144-153, 2012, Precision Assembly Technologies and Systems. 〈10.1007/978-3-642-28163-1_18〉. 〈hal-01363895〉
Share
Metrics
Record views
34
Files downloads
49
