Conference papers
Web Service Composition with Uncertain Non-functional Parameters
Abstract : The problem of service composition is of key importance in the Internet of Things paradigm. A composite Web Service can clearly determine how real life objects described as Web Services could interact with each other. This article proposes a non-functional parameters aggregation algorithm, used in composite service plan optimisation stage, taking into account the uncertainty of the nonfunctional parameters. Also, an optimisation algorithm, using the proposed aggregation method, is presented to show the complete solution for the problem. In this proposition, the algorithm focuses on composite service plan optimisation with uncertain parameters with the given uncertainty description on example of uncertainty parameter. However, the proposed algorithm can be generalized, so it can be used also with other uncertain parameters
Document type :
Conference papers
Complete list of metadatas
Cited literature [13 references]  Display  Hide  Download
https://hal.archives-ouvertes.fr/hal-01348734
Contributor : Hal Ifip <>
Submitted on : Monday, July 25, 2016 - 4:20:00 PM
Last modification on : Monday, July 25, 2016 - 4:46:21 PM
File
978-3-642-37291-9_5_Chapter.pd...
Identifiers
Citation
Łukasz Falas, Paweł Stelmach. Web Service Composition with Uncertain Non-functional Parameters. 4th Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), Apr 2013, Costa de Caparica, Portugal. pp.45-52, ⟨10.1007/978-3-642-37291-9_5⟩. ⟨hal-01348734⟩
Share
Metrics
Record views
141
Files downloads
216
