On the Cauchy problem for the fractional Keller-Segel system in variable Lebesgue spaces
In this paper, we are mainly concerned with the well-posed problem of the fractional Keller–Segel system in the framework of variable Lebesgue spaces. Based on carefully examining the algebraical structure of the system, we reduced the fractional Keller–Segel system into the generalized nonlinear heat equation to overcome the difficulties caused by the boundedness of the Riesz potential in a variable Lebesgue spaces, then by mixing some structural properties of the variable Lebesgue spaces with the optimal decay estimates of the fractional heat kernel, we were able to establish two well-posedness results of the fractional Keller–Segel system in this functional setting.
