Semiclassical Evolution With Low Regularity - Département de mathématiques Accéder directement au contenu
Article Dans Une Revue Journal de Mathématiques Pures et Appliquées Année : 2021
François Golse
  • Fonction : Auteur
  • PersonId : 838357
Thierry Paul
  • Fonction : Auteur
  • PersonId : 878449
  • IdRef : 158973372
We prove semiclassical estimates for the Schr\"odinger-von Neumann evolution with $C^{1,1}$ potentials and density matrices whose square root have either Wigner functions with low regularity independent of the dimension, or matrix elements between Hermite functions having long range decay. The estimates are settled in different weak topologies and apply to initial density operators whose square root have Wigner functions $7$ times differentiable, independently of the dimension. They also apply to the $N$ body quantum dynamics uniformly in $N$. In a appendix, we finally estimate the dependence in the dimension of the constant appearing on the Calderon-Vaillancourt Theorem.
semilowreg5.pdf (663.66 Ko) Télécharger le fichier
hal-02619489 , version 1 (25-05-2020)
hal-02619489 , version 2 (27-11-2020)
François Golse, Thierry Paul. Semiclassical Evolution With Low Regularity. Journal de Mathématiques Pures et Appliquées, 2021, 153, pp.257-311. ⟨hal-02619489v2⟩
149 Consultations
82 Téléchargements
