A Stochastic Formulation of the Disassembly Line Balancing Problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The disassembly line balancing problem is studied under uncertainty. Disassembly task times are assumed random variables with known probability distributions. An AND/OR graph is used to model the precedence relations among tasks. The goal is to assign the disassembly tasks to workstations while respecting precedence and cycle time constraints. The objective is to minimize the total line cost including the incompletion cost arising from task incompletion within the cycle time. A stochastic linear mixed integer programming formulation is developed.
978-3-642-40352-1_50_Chapter.pdf (230.44 Ko) Télécharger le fichier
emse-00766872 , version 1 (21-02-2017)
Paternité
Mohand Lounes Bentaha, Olga Battaïa, Alexandre Dolgui. A Stochastic Formulation of the Disassembly Line Balancing Problem. 19th Advances in Production Management Systems (APMS), Sep 2012, Rhodes, Greece. pp.397-404, ⟨10.1007/978-3-642-40352-1_50⟩. ⟨emse-00766872⟩
344 Consultations
314 Téléchargements
