A Decade in Hindsight: The Missing Bridge Between Multi-Agent Systems and the World Wide Web - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The World Wide Web has evolved drastically over the past decade – and the proliferation of Web APIs has turned it into the middle- ware of choice for most distributed systems. The recent focus on hypermedia-driven APIs together with initiatives such as the Web of Things and Linked Data are now promoting and advancing the development of a new generation of dynamic , open , and long-lived systems on the Web. These systems require agent-based solutions to the point that Web researchers have started to build autonomous systems on their own. It is thus both timely and necessary to in- vestigate and align the latest developments in Web research and multi-agent systems (MAS) research. In this paper, we analyze in hindsight the factors that hindered the widespread acceptance of early Web-based MAS. We argue that the answer lies equally in a lack of practical use cases as well as the premature development and alignment of Web and agent technologies. We then present our vision for a new generation of autonomous systems on the Web, which we call hypermedia MAS , together with the research opportunities and challenges they bring.
Ciortea-et-al-AAMAS2019.pdf (727.85 Ko) Télécharger le fichier
emse-02070625 , version 1 (11-04-2019)
  • HAL Id : emse-02070625 , version 1
Andrei Ciortea, Simon Mayer, Fabien Gandon, Olivier Boissier, Alessandro Ricci, et al.. A Decade in Hindsight: The Missing Bridge Between Multi-Agent Systems and the World Wide Web. AAMAS 2019 - 18th International Conference on Autonomous Agents and Multiagent Systems, May 2019, Montréal, Canada. pp.5. ⟨emse-02070625⟩
605 Consultations
248 Téléchargements
