Staircase Macdonald polynomials and the $q$-Discriminant
We prove that a $q$-deformation $\Disc k\X q$ of the powers of the discriminant is equal, up to a normalization, to a specialization of a Macdonald polynomial indexed by a staircase partition. We investigate the expansion of $\Disc k\X q$ on different basis of symmetric functions. In particular, we show that its expansion on the monomial basis can be explicitly described in terms of standard tableaux and we generalize a result of King-Toumazet-Wybourne about the expansion of the $q$-discriminant on the Schur basis.
Combinatoire [math.CO]
