Minimum time control problems for non autonomous differential equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2009
In this paper, we investigate a minimum time problem for controlled non-autonomous differential systems, with a dynamics depending on the final time. The minimal time function associated to this problem does not satisfy the dynamic programming principle. However, we will prove that it is related to a standard front propagation problem via the reachability function.
R09006.pdf (2.48 Mo) Télécharger le fichier
hal-00387803 , version 1 (25-05-2009)
hal-00387803 , version 2 (24-02-2010)
  • HAL Id : hal-00387803 , version 1
Olivier Bokanowski, Ariela Briani, Hasnaa Zidani. Minimum time control problems for non autonomous differential equations. 2009. ⟨hal-00387803v1⟩
Collections
ENSTA
190 Consultations
381 Téléchargements
