Minimum time control problems for non autonomous differential equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Systems and Control Letters Année : 2009
Olivier Bokanowski
Ariela Briani
Hasnaa Zidani
In this paper, we investigate a minimum time problem for controlled non-autonomous differential systems, with dynamics depending on the final time. The minimal time function associated to this problem does not satisfy the dynamic programming principle. However, we will prove that it is related to a standard front propagation problem via the reachability function. Two simple numerical examples are given to illustrate our approach.
R09006.pdf (2.48 Mo) Télécharger le fichier
hal-00387803 , version 1 (25-05-2009)
hal-00387803 , version 2 (24-02-2010)
Olivier Bokanowski, Ariela Briani, Hasnaa Zidani. Minimum time control problems for non autonomous differential equations. Systems and Control Letters, 2009, 58 (10-11), pp.742-746. ⟨10.1016/j.sysconle.2009.08.003⟩. ⟨hal-00387803v2⟩
190 Consultations
381 Téléchargements
