Upper mantle flow beneath and around the Hangay Dome, central Mongolia - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Earth and Planetary Science Letters Année : 2008
Mongolia represents the northernmost area affected by the India–Asia collision, and it is actively deformed along transpressive belts closely associated with large-scale strike-slip faults. The active and past mantle flow beneath this region is, however, poorly known. In order to investigate deep mantle deformation beneath central Mongolia and its relation with the surrounding major structures such as the Siberian craton, the Gobi–Altay belt and the Baikal rift, a NS-trending profile of broadband seismic stations has been deployed in the summer 2003 from the southern Siberian craton to the Gobi–Altay range, crossing the entire Hangay dome. Mantle flow is deduced from the splitting of teleseismic shear waves such as SKS phases. In eastern Mongolia, the permanent station ULN in Ulaanbaatar reveals the presence of two anisotropic layers, the upper one being oriented NE–SW, close to the trend of lithospheric structures and the lower one NW–SE, close to the trend of Eurasia absolute plate motion. Along the NS profile in central Mongolia, seismic anisotropy deduced from SKS splitting reveals a homogeneous NW–SE trending structure, fully consistent with the observations made in the Altay–Sayan in western Mongolia. The observed delay times of 1.5 to more than 2.0 s favor consistent mantle flow over large mantle thicknesses. Since the lithosphere is less than 100 km thick beneath central Mongolia and since the observed fast directions are parallel to the trend of the lithospheric structures but also close to the trend of the absolute plate motion, we propose that both the lithosphere and the asthenosphere may join their anisotropic effects beneath central Mongolia to explain the large delay times. Although GPS vectors represent the instantaneous displacement of the Earth's surface and SKS splitting the time and vertical integration of finite strain at depth, we use the opportunity of the dense geodetic measurements available in this region to discuss the anisotropy pattern in term of present-day deformation. In the Eurasia-fixed reference frame, GPS and SKS both depict a similar trend beneath central Mongolia, suggesting a lithospheric block “escaping” toward the east that could orient olivine a-axes in the upper mantle, within a transpressive tectonic regime. A different behaviour is observed in western Mongolia: the GPS vectors trend NS, close to the regional compression direction, whereas the fast SKS directions trend EW, suggesting a tectonic regime close to a mode of axial shortening, generating the development of an EW-trending foliation at depth. We therefore propose that Mongolia is a place where active and frozen lithospheric deformation may add their effects, together with the sublithospheric flow. In the three sources of anisotropy inferred, a fundamental role is played by the Siberian craton that acted as an undeformable core of the continent through time: the frozen Paleozoic and Mesozoic structures wrap around the craton, building up the fast anisotropic direction pattern; the present-day sublithospheric flow induced by the plate motion is likely deflecting around its deep roots; finally, the present-day tectonic regime appears to be controlled by the presence of the craton to the north.
Barruol_SKS_Mongolia_EPSL2008_hal.pdf (2.56 Mo) Télécharger le fichier
hal-00407853 , version 1 (24-10-2016)
Guilhem Barruol, Anne Deschamps, Jacques Déverchère, Valentina V. Mordvinova, Ulziibat Munkhuu, et al.. Upper mantle flow beneath and around the Hangay Dome, central Mongolia. Earth and Planetary Science Letters, 2008, 274 (1-2), pp.221-233. ⟨10.1016/j.epsl.2008.07.027⟩. ⟨hal-00407853⟩
1865 Consultations
318 Téléchargements
