Exponential stability and stabilization of sampled-data systems with time-varying period - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Conference Papers Year : 2010
This article proposes a novel approach to assess the exponential stability of linear systems with sampled-data inputs. The paper considers both uncertainties in the model parameters and in the sampling period. Inspired by the input-delay approach and the stability of impulsive systems, the proposed method provides easy tractable stability conditions. Sufficient stability and stabilization conditions are provided to deal with both cases of constant and time-varying sampling periods. The period-dependent conditions are expressed using computable linear matrix inequalities. Several examples show the efficiency and the limitation of such stability criteria.
Domains
Automatic
TDSDel2010FV.pdf (158.26 Ko) Télécharger le fichier
Dates and versions
hal-00458829 , version 1 (22-02-2010)
Identifiers
  • HAL Id : hal-00458829 , version 1
Cite
Alexandre Seuret. Exponential stability and stabilization of sampled-data systems with time-varying period. IFAC TDS 2010 - 9th IFAC Workshop on Time Delay Systems, Jun 2010, Prague, Czech Republic. ⟨hal-00458829⟩
392 View
299 Download
Share
