Minimization of an energy error functional to solve a Cauchy problem arising in plasma physics: the reconstruction of the magnetic flux in the vacuum surrounding the plasma in a Tokamak - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Revue Africaine de Recherche en Informatique et Mathématiques Appliquées Année : 2012
A numerical method for the computation of the magnetic flux in the vacuum surrounding the plasma in a Tokamak is investigated. It is based on the formulation of a Cauchy problem which is solved through the minimization of an energy error functional. Several numerical experiments are conducted which show the efficiency of the method.
BF2012-arimarevised-hal.pdf (386.81 Ko) Télécharger le fichier
hal-00481257 , version 3 (17-11-2013)
hal-00481257 , version 2 (07-04-2016)
Blaise Faugeras, Amel Ben Abda, Jacques Blum, Cedric Boulbe. Minimization of an energy error functional to solve a Cauchy problem arising in plasma physics: the reconstruction of the magnetic flux in the vacuum surrounding the plasma in a Tokamak. Revue Africaine de Recherche en Informatique et Mathématiques Appliquées, 2012, Volume 15, 2012, pp.37-60. ⟨10.46298/arima.1957⟩. ⟨hal-00481257v3⟩
951 Consultations
891 Téléchargements
