Reconstructing Plant Architecture from 3D Laser scanner data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Automatic acquisition of plant phenotypes constitutes a major bottleneck in the construction of quantitative models of plant development. This issue needs to be addressed to build accurate models of plant, useful for instance in agronomic and forestry applications. In this work, we present a method for reconstructing plant architecture from laser scanner data. A dedicated evaluation procedure based on a detailed comparison between expert and automatic reconstruction was developed to quantify accurately the quality of the reconstruction method.
Laser-FSPM10-final.pdf (376.99 Ko) Télécharger le fichier
Format : Figure, Image
hal-00490064 , version 1 (05-10-2010)
  • HAL Id : hal-00490064 , version 1
Chakkrit Preuksakarn, Frédéric Boudon, Pascal Ferraro, Jean-Baptiste Durand, Ekko Nikinmaa, et al.. Reconstructing Plant Architecture from 3D Laser scanner data. 6th International Workshop on Functional-Structural Plant Models, Sep 2010, Davis, United States. pp.12--17. ⟨hal-00490064⟩
1363 Consultations
1145 Téléchargements
