Reconstructing Plant Architecture from 3D Laser scanner data
Automatic acquisition of plant phenotypes constitutes a major bottleneck in the construction of quantitative models of plant development. This issue needs to be addressed to build accurate models of plant, useful for instance in agronomic and forestry applications. In this work, we present a method for reconstructing plant architecture from laser scanner data. A dedicated evaluation procedure based on a detailed comparison between expert and automatic reconstruction was developed to quantify accurately the quality of the reconstruction method.
Laser-FSPM10-final.pdf (376.99 Ko)
Télécharger le fichier
Format : Figure, Image
