Delay dependent stability analysis of interval time-delay systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We consider interval time-varying delay systems. The time-delay interval is divided into several zones and the systems switch among the different zones. Based on Lyapunov-Krasovskii functional methods and on linear matrix inequality (LMI) techniques, exponential stability is exploited for every time-delay zone. The global stability of the switched system is guaranteed if some minimum average dwell time conditions are satisfied. Numerical examples and comparisons with other works show that the methods enlarge the value of the maximum upper-bound of allowable time-delays.
TDS10_final.pdf (122.14 Ko) Télécharger le fichier
hal-00519491 , version 1 (20-09-2010)
  • HAL Id : hal-00519491 , version 1
Wenjuan Jiang, Alexandre Kruszewski, Emilia Fridman, Jean-Pierre Richard. Delay dependent stability analysis of interval time-delay systems. IFAC TDS 2010 - 9th IFAC Workshop on Time Delay Systems, Jun 2010, Prague, Czech Republic. ⟨hal-00519491⟩
934 Consultations
228 Téléchargements
