New interface
Journal articles
Reduced-order modeling for cardiac electrophysiology. Application to parameter identification
Muriel Boulakia 1, 2 Elisa Schenone 1, 2 Jean-Frédéric Gerbeau 1
1 REO - Numerical simulation of biological flows
LJLL - Laboratoire Jacques-Louis Lions, Inria Paris-Rocquencourt, UPMC - Université Pierre et Marie Curie - Paris 6
Abstract : A reduced-order model based on Proper Orthogonal Decomposition (POD) is proposed for the bidomain equations of cardiac electrophysiology. Its accuracy is assessed through electrocardiograms in various configurations, including myocardium infarctions and long-time simulations. We show in particular that a restitution curve can efficiently be approximated by this approach. The reduced-order model is then used in an inverse problem solved by an evolutionary algorithm. Some attempts are presented to identify ionic parameters and infarction locations from synthetic ECGs.
Document type :
Journal articles
Complete list of metadata
Cited literature [34 references]  Display  Hide  Download
https://hal.inria.fr/hal-00644396
Contributor : Elisa Schenone Connect in order to contact the contributor
Submitted on : Wednesday, December 7, 2011 - 10:01:28 AM
Last modification on : Friday, January 21, 2022 - 3:21:51 AM
Long-term archiving on: : Monday, December 5, 2016 - 7:18:35 AM
RR-7811.pdf
Identifiers
Citation
Muriel Boulakia, Elisa Schenone, Jean-Frédéric Gerbeau. Reduced-order modeling for cardiac electrophysiology. Application to parameter identification. International Journal for Numerical Methods in Biomedical Engineering, 2012, 28, pp.727-744. ⟨10.1002/cnm.2465⟩. ⟨hal-00644396v2⟩
Share
Metrics
Record views
258
Files downloads
245
