Approximation of the hydrostatic Navier-Stokes system for density stratified flows by a multilayer model. Kinetic interpretation and numerical solution. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Computational Physics Année : 2011
We present a multilayer Saint-Venant system for the numerical simulation of free surface density-stratified flows over variable topography. The proposed model formally approxi- mates the hydrostatic Navier-Stokes equations with a density that varies depending on the spatial and temporal distribution of a transported quantity such as temperature or salinity. The derivation of the multilayer model is obtained by a Galerkin-type vertical dis- cretization of the Navier-Stokes system with piecewise constant basis functions. In con- trast with classical multilayer models in the literature that assume immiscible fluids, we allow here for mass exchange between layers. We show that the multilayer system admits a kinetic interpretation, and we use this result to formulate a robust finite volume scheme for its numerical approximation. Several numerical experiments are presented, including simulations of wind-driven stratified flows.
hal-00654642 , version 1 (22-12-2011)
Emmanuel Audusse, Marie-Odile Bristeau, Marica Pelanti, Jacques Sainte-Marie. Approximation of the hydrostatic Navier-Stokes system for density stratified flows by a multilayer model. Kinetic interpretation and numerical solution.. Journal of Computational Physics, 2011, 230, pp.3453-3478. ⟨10.1016/j.jcp.2011.01.042⟩. ⟨hal-00654642⟩
413 Consultations
0 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
