Construction of real algebraic numbers in Coq
This paper shows a construction in Coq of the set of real algebraic numbers, together with a formal proof that this set has a structure of discrete archimedian real closed field. This construction hence implements an interface of real closed field. Instances of such an interface immediately enjoy quantifier elimination thanks to a previous work. This work also intends to be a basis for the construction of complex algebraic numbers and to be a reference implementation for the certification of numerous algorithms relying on algebraic numbers in computer algebra.
