Construction of real algebraic numbers in Coq - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper shows a construction in Coq of the set of real algebraic numbers, together with a formal proof that this set has a structure of discrete archimedian real closed field. This construction hence implements an interface of real closed field. Instances of such an interface immediately enjoy quantifier elimination thanks to a previous work. This work also intends to be a basis for the construction of complex algebraic numbers and to be a reference implementation for the certification of numerous algorithms relying on algebraic numbers in computer algebra.
main.pdf (444.37 Ko) Télécharger le fichier
hal-00671809 , version 1 (18-02-2012)
hal-00671809 , version 2 (13-06-2012)
  • HAL Id : hal-00671809 , version 2
Cyril Cohen. Construction of real algebraic numbers in Coq. ITP - 3rd International Conference on Interactive Theorem Proving - 2012, Aug 2012, Princeton, United States. ⟨hal-00671809v2⟩
776 Consultations
1508 Téléchargements
