On the Commuting variety of a reductive Lie algebra and other related varieties. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2012
Jean-Yves Charbonnel
  • Fonction : Auteur
  • PersonId : 830424
Mouchira Zaiter
  • Fonction : Auteur
  • PersonId : 923256
In this note, one discusses about some varieties which are constructed analogously to the isospectral commuting varieties. These varieties are subvarieties of varieties having very simple desingularizations. For instance, this is the case of the nullcone of any cartesian power of a reductive Lie algebra and one proves that it has rational singularities. Moreover, as a byproduct of these investigations and the Ginzburg's results, one gets that the normalizations of the isospectral commuting variety and the commuting variety have rational singularities.
vc.pdf (471.42 Ko) Télécharger le fichier
hal-00684400 , version 1 (02-04-2012)
hal-00684400 , version 2 (10-10-2012)
hal-00684400 , version 3 (22-12-2014)
hal-00684400 , version 4 (01-04-2015)
hal-00684400 , version 5 (10-06-2015)
hal-00684400 , version 6 (20-07-2015)
hal-00684400 , version 7 (20-04-2016)
Jean-Yves Charbonnel, Mouchira Zaiter. On the Commuting variety of a reductive Lie algebra and other related varieties.. 2012. ⟨hal-00684400v1⟩
241 Consultations
295 Téléchargements
