On the Commuting variety of a reductive Lie algebra and other related varieties. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2014
Jean-Yves Charbonnel
  • Fonction : Auteur
  • PersonId : 830424
Mouchira Zaiter
  • Fonction : Auteur
  • PersonId : 962656
In this note, we discuss some varieties which are constructed analogously to the isospectral commuting varieties. These varieties are subvarieties of varieties having very simple desingularizations. For instance, this is the case of the nullcone of any cartesian power of a reductive Lie algebra and we prove that it is normal. Moreover, as a byproduct of these investigations and a Ginzburg's result, we get that the normalizations of the isospectral commuting variety and the commuting variety have rational singularities.
vc.pdf (388.24 Ko) Télécharger le fichier
hal-00684400 , version 1 (02-04-2012)
hal-00684400 , version 2 (10-10-2012)
hal-00684400 , version 3 (22-12-2014)
hal-00684400 , version 4 (01-04-2015)
hal-00684400 , version 5 (10-06-2015)
hal-00684400 , version 6 (20-07-2015)
hal-00684400 , version 7 (20-04-2016)
Jean-Yves Charbonnel, Mouchira Zaiter. On the Commuting variety of a reductive Lie algebra and other related varieties.. 2014. ⟨hal-00684400v3⟩
241 Consultations
295 Téléchargements
