A staggered discontinuous Galerkin method for wave propagation in media with dielectrics and meta-materials - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Autre Publication Année : 2012
Some electromagnetic materials exhibit, in a given frequency range, effective dielectric permittivity and/or magnetic permeability which are negative. In the literature, they are called negative index materials, left-handed materials or meta-materials. We propose in this paper a numerical method to solve a wave transmission between a classical dielectric material and a meta-material. The method we investigate can be considered as an alternative method compared to the method presented by the second author and co-workers. In particular, we shall use the abstract framework they developed to prove well-posedness of the exact problem. We recast this problem to fit later discretization by the staggered discontinuous Galerkin method developed by the first author and co-worker, a method which relies on introducing an auxiliary unknown. Convergence of the numerical method is proven, with the help of explicit inf-sup operators, and numerical examples are provided to show the efficiency of the method.
ChCi12-DG.pdf (259.54 Ko) Télécharger le fichier
hal-00697755 , version 1 (16-05-2012)
  • HAL Id : hal-00697755 , version 1
Eric T. Chung, Patrick Ciarlet. A staggered discontinuous Galerkin method for wave propagation in media with dielectrics and meta-materials. 2012. ⟨hal-00697755⟩
590 Consultations
199 Téléchargements
