Exterior sphere condition and time optimal control for differential inclusions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Control and Optimization Année : 2011
Piermarco Cannarsa
  • Fonction : Auteur
  • PersonId : 859188
Khai T. Nguyen
  • Fonction : Auteur
The minimum time function $T(\cdot)$ of smooth control systems is known to be locally semiconcave provided Petrov's controllability condition is satisfied. Moreover, such a regularity holds up to the boundary of the target under an inner ball assumption. We generalize this analysis to differential inclusions, replacing the above hypotheses with the continuity of $T(\cdot)$ near the target, and an inner ball property for the multifunction associated with the dynamics. In such a weakened set-up, we prove that the hypograph of $T(\cdot)$ satisfies, locally, an exterior sphere condition. As is well-known, this geometric property ensures most of the regularity results that hold for semiconcave functions, without assuming $T(\cdot)$ to be Lipschitz.
hal-00710651 , version 1 (21-06-2012)
Piermarco Cannarsa, Khai T. Nguyen. Exterior sphere condition and time optimal control for differential inclusions. SIAM Journal on Control and Optimization, 2011, 49 (6), pp.2558-2576. ⟨10.1137/110825078⟩. ⟨hal-00710651⟩
Collections
SADCO TDS-MACS
78 Consultations
0 Téléchargements
