Linear programming based Lyapunov function computation for differential inclusions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete and Continuous Dynamical Systems - Series B Année : 2012
We present a numerical algorithm for computing Lyapunov functions for a class of strongly asymptotically stable nonlinear differential inclusions which includes spatially switched systems and systems with uncertain parameters. The method relies on techniques from nonsmooth analysis and linear programming and constructs a piecewise affine Lyapunov function. We provide necessary background material from nonsmooth analysis and a thorough analysis of the method which in particular shows that whenever a Lyapunov function exists then the algorithm is in principle able to compute it. Two numerical examples illustrate our method.
hal-00724864 , version 1 (22-08-2012)
Robert Baier, Lars Grüne, Sigurđur Freyr Hafstein. Linear programming based Lyapunov function computation for differential inclusions. Discrete and Continuous Dynamical Systems - Series B, 2012, 17 (1), pp.33-56. ⟨10.3934/dcdsb.2012.17.33⟩. ⟨hal-00724864⟩
95 Consultations
1 Téléchargements
