OSAMOAL: optimized simulations by adapted models using asymptotic limits - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ESAIM: Proceedings and Surveys Année : 2012
We propose in this work to address the problem of model adaptation, dedicated to hyper- bolic models with relaxation and to their parabolic limit. The goal is to replace a hyperbolic system of balance laws (the so-called fine model) by its parabolic limit (the so-called coarse model), in delimited parts of the computational domain. Our method is based on the construction of asymptotic preserving schemes and on interfacial coupling methods between hyperbolic and parabolic models. We study in parallel the cases of the Goldstein-Taylor model and of the p-system with friction.
BCMSS-revised.pdf (303.33 Ko) Télécharger le fichier
hal-00733865 , version 1 (19-09-2012)
Anne-Céline Boulanger, Clément Cancès, Hélène Mathis, Khaled Saleh, Nicolas Seguin. OSAMOAL: optimized simulations by adapted models using asymptotic limits. ESAIM: Proceedings and Surveys, 2012, 38, pp.183-201. ⟨10.1051/proc/201238010⟩. ⟨hal-00733865⟩
778 Consultations
197 Téléchargements
