An adaptive sparse grid semi-lagrangian scheme for first order Hamilton-Jacobi Bellman equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Scientific Computing Année : 2013
We propose a semi-Lagrangian scheme using a spatially adaptive sparse grid to deal with non-linear time-dependent Hamilton-Jacobi Bellman equations. We focus in particular on front propagation models in higher dimensions which are related to control problems. We test the numerical efficiency of the method on several benchmark problems up to space dimension d = 8, and give evidence of convergence towards the exact viscosity solution. In addition, we study how the complexity and precision scale with the dimension of the problem.
Bokanowski_Garcke_Griebel_Klompmaker_jsc.pdf (2.77 Mo) Télécharger le fichier
hal-00741178 , version 1 (12-10-2012)
Olivier Bokanowski, Jochen Garcke, Michael Griebel, Irene Klompmaker. An adaptive sparse grid semi-lagrangian scheme for first order Hamilton-Jacobi Bellman equations. Journal of Scientific Computing, 2013, 55, pp. 575-605. ⟨10.1007/s10915-012-9648-x⟩. ⟨hal-00741178⟩
473 Consultations
576 Téléchargements
