Influence of the singular manifold of non observable states in reconstructing chaotic attractors
It is known that the reconstructed phase portrait of a given system strongly depends on the choice of the observable. In particular, the ability to obtain a global model from a time series strongly depends on the observability provided by the measured variable. Such a dependency results from i) the existence of a singular observability manifold for which the coordinate transformation ii) how often the trajectory visits the neighborhood of the observability singularity manifold (OSM). In order to clarify how these aspects contribute to the observability coefficients, we introduce the probability of visits of OSM and the relative time spent in OSM to construct a new coefficient. Combined with the symbolic observability coefficients previously introduced by one of the authors.
Systèmes dynamiques [math.DS]
