The wave-front tracking algorithm for Hughes' model of pedestrian motion - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Scientific Computing Année : 2013
We code the wave-front tracking algorithm for Hughes' model of pedestrian motion with generalized running cost. This model displays a non-classical dynamic at the splitting point between the two directions of motion. The wave-front tracking scheme provides us with reference solutions to test numerically the convergence of classical finite volume schemes, which do not treat explicitly the dynamics at the turning point.
wft_pedestrians.pdf (342.97 Ko) Télécharger le fichier
hal-00751260 , version 1 (13-11-2012)
  • HAL Id : hal-00751260 , version 1
Paola Goatin, Matthias Mimault. The wave-front tracking algorithm for Hughes' model of pedestrian motion. SIAM Journal on Scientific Computing, 2013, 35 (3), pp.B606-B622. ⟨hal-00751260⟩
1148 Consultations
991 Téléchargements
