Square root algorithms for the number field sieve - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We review several methods for the square root step of the Number Field Sieve, and present an original one, based on the Chinese Remainder Theorem.
nfs-sqrt.pdf (245.29 Ko) Télécharger le fichier
hal-00756838 , version 1 (23-11-2012)
Emmanuel Thomé. Square root algorithms for the number field sieve. Arithmetic of Finite Fields -- WAIFI 2012, Jul 2012, Bochum, Germany. pp.208-224, ⟨10.1007/978-3-642-31662-3_15⟩. ⟨hal-00756838⟩
323 Consultations
285 Téléchargements
