Numerical resolution of conservation laws with OpenCL - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ESAIM: Proceedings Année : 2013
We present several numerical simulations of conservation laws on recent multicore processors, such as GPU's, using the OpenCL programming framework. Depending on the chosen numerical method, different implementation strategies have to be considered, for achieving the best performance. We explain how to program efficiently three methods: a finite volume approach on a structured grid, a high order Discontinuous Galerkin (DG) method on an unstructured grid and a Particle-In-Cell (PIC) method. The three methods are respectively applied to a two-fluid computation, a Maxwell simulation and a Vlasov-Maxwell simulation.
esaim-opencl.pdf (648.01 Ko) Télécharger le fichier
hal-00759131 , version 1 (30-11-2012)
Anaïs Crestetto, Philippe Helluy, Jonathan Jung. Numerical resolution of conservation laws with OpenCL. ESAIM: Proceedings, 2013, 40, pp.51-62. ⟨10.1051/proc/201340004⟩. ⟨hal-00759131⟩
281 Consultations
390 Téléchargements
