Push-relabel based algorithms for the maximum transversal problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computers and Operations Research Année : 2013
We investigate the push-relabel algorithm for solving the problem of finding a maximum cardinality matching in a bipartite graph in the context of the maximum transversal problem. We describe in detail an optimized yet easy-to-implement version of the algorithm and fine-tune its parameters. We also introduce new performance-enhancing techniques. On a wide range of real-world instances, we compare the push-relabel algorithm with state-of-the-art algorithms based on augmenting paths and pseudoflows. We conclude that a carefully tuned push-relabel algorithm is competitive with all known augmenting path-based algorithms, and superior to the pseudoflow-based ones.
paper.pdf (437.68 Ko) Télécharger le fichier
hal-00763920 , version 1 (07-03-2013)
Kamer Kaya, Johannes Langguth, Fredrik Manne, Bora Uçar. Push-relabel based algorithms for the maximum transversal problem. Computers and Operations Research, 2013, 40 (5), pp.1266-1275. ⟨10.1016/j.cor.2012.12.009⟩. ⟨hal-00763920⟩
277 Consultations
671 Téléchargements
