Excision in equivariant cohomology with emphasis on SL_2 over imaginary quadratic integers
We extend the Torsion Sub-complex Reduction technique to the case where the kernel of a group action is non-trivial. For this purpose, we excise the non-central torsion sub-complex from the equivariant spectral sequence. This new method of excision in equivariant cohomology is elaborated in a general setting. We demonstrate the power of the method by establishing general dimension formulae for the second page of the equivariant spectral sequence of the action of the SL_2 groups over imaginary quadratic integers on their associated symmetric space.
K-théorie et homologie [math.KT]
Berkove_and_Rahm_-_Excision_in_equivariant_cohomology.pdf (269.88 Ko)
Télécharger le fichier
