The mod 2 cohomology rings of SL_2 of the imaginary quadratic integers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2013
Ethan Berkove
  • Fonction : Auteur
  • PersonId : 934709
Alexander D. Rahm
Connectez-vous pour contacter l'auteur
When a group acts cellularly on a space, the torsion subcomplex contains all of the homological information at a given prime number. The recently introduced technique of torsion subcomplex reduction has been successfully applied under certain hypotheses to determine the Farrell cohomology of discrete groups. In this paper, we extend the torsion subcomplex reduction technique to the case where the kernel of the group action is nontrivial. This is accomplished by algebraically excising the torsion subcomplex from the equivariant spectral sequence. We demonstrate the power of this "découpage in equivariant cohomology" by establishing general dimension formulae for the second page of the equivariant spectral sequence of the action of the SL_2 groups over imaginary quadratic integers on their associated symmetric space. Then, we show how to obtain the mod 2 cohomology rings of our groups from this information.
Berkove_and_Rahm_-_Excision_in_equivariant_cohomology.pdf (400.35 Ko) Télécharger le fichier
hal-00769261 , version 1 (30-12-2012)
hal-00769261 , version 2 (08-07-2013)
hal-00769261 , version 3 (08-10-2014)
hal-00769261 , version 4 (22-07-2015)
hal-00769261 , version 5 (20-08-2016)
  • HAL Id : hal-00769261 , version 2
Ethan Berkove, Alexander D. Rahm. The mod 2 cohomology rings of SL_2 of the imaginary quadratic integers. 2013. ⟨hal-00769261v2⟩
317 Consultations
275 Téléchargements
