Gauss-Hermite wavepacket dynamics: convergence of the spectral and pseudo-spectral approximation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IMA Journal of Numerical Analysis Année : 2009
The time dependent linear Schrödinger equation for nuclei on the whole space is semi-discretised using Hermite and Gauss-Hermite basis functions. These are well suited on the one hand for the conservation properties of the numerical solution and, on the other hand, for their remarkable approximation properties. We investigate theoretically and numerically the convergence of the spectral and pseudo- spectral Gauss-Hermite semi-discretisation schemes. Schrödinger equation, Gauss- Hermite approximation, spectral and pseudo-spectral methods
Fichier non déposé
hal-00777661 , version 1 (17-01-2013)
  • HAL Id : hal-00777661 , version 1
Erwan Faou, Vasile Gradinaru. Gauss-Hermite wavepacket dynamics: convergence of the spectral and pseudo-spectral approximation. IMA Journal of Numerical Analysis, 2009, 29, pp.1023-1045. ⟨hal-00777661⟩
159 Consultations
0 Téléchargements
