The snapping out Brownian motion - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2012
We give a probabilistic representation of a one-dimensional diffusion, equation where the solution is discontinuous at 0 with a jump proportional to its flux. This kind of interface condition is usually seen as a semi-permeable barrier. For this, we use a process called here the snapping out Brownian motion, whose properties are studied. As this construction is motivated by applications, for example in brain imaging or in chemistry, a simulation scheme is also provided.
snapping-out-brownian-motion.pdf (242.78 Ko) Télécharger le fichier
hal-00781447 , version 1 (26-01-2013)
hal-00781447 , version 2 (06-01-2015)
hal-00781447 , version 3 (09-07-2015)
hal-00781447 , version 4 (03-08-2015)
  • HAL Id : hal-00781447 , version 1
Antoine Lejay. The snapping out Brownian motion. 2012. ⟨hal-00781447v1⟩
354 Consultations
521 Téléchargements
