Computability of the entropy of one-tape Turing Machines - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We prove that the maximum speed and the entropy of a one-tape Turing machine are computable, in the sense that we can approximate them to any given precision $\epsilon$. This is contrary to popular belief, as all dynamical properties are usually undecidable for Turing machines. The result is quite specific to one-tape Turing machines, as it is not true anymore for two-tape Turing machines by the results of Blondel et al., and uses the approach of crossing sequences introduced by Hennie.
entropy.pdf (183.04 Ko) Télécharger le fichier
hal-00785232 , version 1 (05-02-2013)
Emmanuel Jeandel. Computability of the entropy of one-tape Turing Machines. STACS - Symposium on Theoretical Aspects of Computer Science, Mar 2014, Lyon, France. pp.421-432, ⟨10.4230/LIPIcs.STACS.2014.421⟩. ⟨hal-00785232⟩
380 Consultations
289 Téléchargements
