Perceptual Affordances of Wall-Sized Displays for Visualization Applications: Color - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Anastasia Bezerianos
Petra Isenberg
Olivier Chapuis
Wall-sized displays offer the opportunity to display very large information spaces. Most data representations can be scaled to wall size but display walls are not simply big desktop monitors. We do not yet know how the perceptual affordances of a wall, such as the wide viewing angles they cover, affect how data is perceived and comprehended. In this paper we call for more studies on the perception of data on wall-sized displays and discuss-with the example of color-several aspects of wall setups that we hypothesize will most affect the perception of this visual variable.
Bezerianos_2013_PAO.pdf (6.36 Mo) Télécharger le fichier
Format : Figure, Image
hal-00799486 , version 1 (12-03-2013)
  • HAL Id : hal-00799486 , version 1
Anastasia Bezerianos, Petra Isenberg, Olivier Chapuis, Wesley Willett. Perceptual Affordances of Wall-Sized Displays for Visualization Applications: Color. Proceedings of the CHI Workshop on Interactive, Ultra-High-Resolution Displays (PowerWall), Apr 2013, Paris, France. ⟨hal-00799486⟩
421 Consultations
415 Téléchargements
