Synchronization of an Excitatory Integrate-and-Fire Neural Network - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Bulletin of Mathematical Biology Année : 2013
In this paper, we study the influence of the coupling strength on the synchronization behavior of a population of leaky integrate-and-fire neurons that is selfexcitatory with a population density approach. Each neuron of the population is assumed to be stochastically driven by an independent Poisson spike train and the synaptic interaction between neurons is modeled by a potential jump at the reception of an action potential. Neglecting the synaptic delay, we will establish that for a strong enough connectivity between neurons, the solution of the partial differential equation which describes the population density function must blow up in finite time. Furthermore, we will give a mathematical estimate on the average connection per neuron to ensure the occurrence of a burst. Interpreting the blow up of the solution as the presence of a Dirac mass in the firing rate of the population, we will relate the blow up of the solution to the occurrence of the synchronization of neurons. Fully stochastic simulations of a finite size network of leaky integrate-and-fire neurons are performed to illustrate our theoretical results.
explosion-revised.pdf (659.09 Ko) Télécharger le fichier
hal-00822472 , version 1 (14-05-2013)
Grégory Dumont, Jacques Henry. Synchronization of an Excitatory Integrate-and-Fire Neural Network. Bulletin of Mathematical Biology, 2013, 75 (4), pp.629-648. ⟨10.1007/s11538-013-9823-8⟩. ⟨hal-00822472⟩
214 Consultations
231 Téléchargements
