A Fault-Tolerant Approach to Distributed Applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Distributed computing infrastructures support system and network fault-tolerance, e.g., grids and clouds. They transparently repair and prevent communication and system software errors. They also allow duplication and migration of jobs and data to prevent hardware failures. However, only limited work has been done so far on application resilience, i.e., the ability to resume normal execution after errors and abnormal executions in distributed environments. This paper addresses issues in application resilience, i.e., fault-tolerance to algorithmic errors and to resource allocation failures. It addresses solutions for error detection and management. It also overviews a platform used to deploy, execute, monitor, restart and resume distributed applications on grids and cloud infrastructures in case of unexpected behavior.
PDPTA2013.pdf (339.85 Ko) Télécharger le fichier
hal-00823329 , version 1 (16-05-2013)
hal-00823329 , version 2 (16-05-2013)
hal-00823329 , version 3 (13-06-2013)
  • HAL Id : hal-00823329 , version 2
Toan Nguyen, Jean-Antoine Desideri, Laurentiu Trifan. A Fault-Tolerant Approach to Distributed Applications. Parallel and Distributed Processing Techniques and Applications (PDPTA'13), Jul 2013, Las Vegas, United States. ⟨hal-00823329v2⟩
218 Consultations
281 Téléchargements
