Foliage randomness and light interception in 3D digitized trees:an analysis of 3D discretization of the canopy - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Plant, Cell and Environment Année : 2005
Light models for vegetation canopies based on the turbid medium analogy are usually limited by the basic assumption of random foliage dispersion in the canopy space. The objective of this paper was to assess the effect of three possible sources of non-randomness in tree canopies on light interception properties. For this purpose, four three-dimensional (3-D) digitized trees and four theoretical canopies – one random and three built from fractal rules – were used to compute canopy structure parameters and light interception, namely the sky-vault averaged STAR (Silhouette to Total Area Ratio). STAR values were computed from (1) images of the 3-D plants, and (2) from a 3-D turbid medium model using space discretization at different scales. For all trees, departure from randomness was mainly due to the spatial variations in leaf area density within the canopy volume. Indeed STAR estimations, based on turbid medium assumption, using the finest space discretization were very close to STAR values computed from the plant images. At this finest scale, foliage dispersion was slightly clumped, except one theoretical fractal canopy, which showed a marked regular dispersion. Taking into account a non-infinitely small leaf size, whose effect is theoretically to shorten self-shading, had a minor effect on STAR computations. STAR values computed from the 3-D turbid medium were very sensitive to plant lacunarity, a parameter introduced in the context of fractal studies to characterize the distribution of gaps in porous media at different scales. This study shows that 3-D turbid medium models based on space discretization are able to give correct estimation of light interception by 3-D isolated trees, provided that the 3-D grid is properly defined, that is, discretization maximizes plant lacunarity.
hal-00830072 , version 1 (04-06-2013)
Hervé Sinoquet, Gabriela Sonohat, Jessada Phattaralerphong, Christophe Godin. Foliage randomness and light interception in 3D digitized trees:an analysis of 3D discretization of the canopy. Plant, Cell and Environment, 2005, 29 (9), pp.1158-1170. ⟨10.1111/j.1365-3040.2005.01353.x⟩. ⟨hal-00830072⟩
236 Consultations
0 Téléchargements
