Nonparametric estimation of extreme risks from conditional heavy-tailed distributions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2013
In this paper, we introduce a new risk measure, the so-called Conditional Tail Moment. It is the moment of order a>0 of the loss distribution above the upper alpha-quantile. Estimating the Conditional Tail Moment permits to estimate all risk measures based on conditional moments such as Value-at-Risk, Conditional Tail Expectation, Conditional Value-at-Risk or Conditional Tail Variance. Here, we focus on the estimation of these risk measures in case of extreme losses (where alpha converges to 0). It is moreover assumed that the loss distribution is heavy-tailed and depends on a covariate. The estimation method thus combines nonparametric kernel methods with extreme-value statistics. The asymptotic distribution of the estimators is established and their finite sample behavior is illustrated both on simulated data and on a real data set of daily rainfalls in the Cévennes-Vivarais region (France).
CTM.pdf (349.05 Ko) Télécharger le fichier
hal-00830647 , version 1 (05-06-2013)
hal-00830647 , version 2 (10-06-2013)
hal-00830647 , version 3 (22-08-2013)
hal-00830647 , version 4 (19-09-2013)
hal-00830647 , version 5 (28-11-2013)
  • HAL Id : hal-00830647 , version 1
Jonathan El Methni, Laurent Gardes, Stéphane Girard. Nonparametric estimation of extreme risks from conditional heavy-tailed distributions. 2013. ⟨hal-00830647v1⟩
1057 Consultations
1294 Téléchargements
