Transition probabilities for piecewise affine models of genetic networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In the piecewise affine framework, trajectories evolve among hyperrectangles in the state space. A qualitative description of the dynamics - useful for models of genetic networks - can be obtained by viewing each hyperrectangle as a node in a discrete system, so that trajectories follow a path in a transition graph. In this paper, a probabilistic interpretation is given for the transition between two nodes A and B, based on the volume of the initial conditions on hyperrectangle A whose trajectories cross to B. In an example consisting of two intertwinned negative loops, this probabilistic interpretation is used to predict the most likely periodic orbit given a set of parameters, or to find parameters such that the system yields a desired periodic orbit with a high probability.
ChavesFarcotGouze-MTNS10.pdf (214.09 Ko) Télécharger le fichier
Format : Figure, Image
hal-00831793 , version 1 (07-06-2013)
  • HAL Id : hal-00831793 , version 1
Madalena Chaves, Etienne Farcot, Jean-Luc Gouzé. Transition probabilities for piecewise affine models of genetic networks. Proc. Int. Symp. Mathematical Theory of Networks and Systems (MTNS 10), Budapest, Hungary, Jul. 2010., 2010, Budapest, Hungary. ⟨hal-00831793⟩
246 Consultations
57 Téléchargements
