Convergence of discontinuous Galerkin schemes for front propagation with obstacles - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2014
Yingda Cheng
  • Fonction : Auteur
  • PersonId : 916363
Chi-Wang Shu
  • Fonction : Auteur
  • PersonId : 916362
We study semi-Lagrangian discontinuous Galerkin (SLDG) and Runge-Kutta discontinuous Galerkin (RKDG) schemes for some front propagation problems in the presence of an obstacle term, modeled by a nonlinear Hamilton-Jacobi equation of the form $\min(u_t + c u_x, u - g(x))=0$, in one space dimension. New convergence results and error bounds are obtained for Lipschitz regular data. These ''low regularity" assumptions are the natural ones for the solutions of the studied equations.
main.pdf (251.03 Ko) Télécharger le fichier
hal-00834342 , version 1 (14-06-2013)
hal-00834342 , version 2 (23-09-2014)
hal-00834342 , version 3 (25-02-2015)
Olivier Bokanowski, Yingda Cheng, Chi-Wang Shu. Convergence of discontinuous Galerkin schemes for front propagation with obstacles. 2014. ⟨hal-00834342v2⟩
444 Consultations
448 Téléchargements
