On the Cauchy problem for dispersive equations with nonlinear terms involving high derivatives and with arbitrarily large initial data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Nonlinear Analysis: Theory, Methods and Applications Année : 1994
Thierry Colin
  • Fonction : Auteur
  • PersonId : 836679
  • IdRef : 069826188
The aim of this article is to study the Cauchy problem for general nonlinear dispersive equations involving derivatives in the nonlinearity. The use of some decay properties of the linear part allows us to address the case of arbitrarily large initial data.
bibi1.pdf (244.71 Ko) Télécharger le fichier
hal-00848097 , version 1 (25-07-2013)
Thierry Colin. On the Cauchy problem for dispersive equations with nonlinear terms involving high derivatives and with arbitrarily large initial data. Nonlinear Analysis: Theory, Methods and Applications, 1994, 22 (7), pp.835-845. ⟨10.1016/0362-546X(94)90052-3⟩. ⟨hal-00848097⟩
172 Consultations
230 Téléchargements
